- Messages
- 10,619
BG boys have a gas rate calculator on their laptops you just put in the two readings or time taken and it does all the work anyone know if its available anywhere preferably free?
Discuss gas rate calculator in the Plumbing Jobs | The Job-board area at PlumbersForums.net
send me a PM and i will send you a spreadsheet, all you have to do is input the gas used after 2mins or the time taken to burn 1cu3BG boys have a gas rate calculator on their laptops you just put in the two readings or time taken and it does all the work anyone know if its available anywhere preferably free?
its no that difficult. if its an imperial meter divide the amount of secs by 1098 and if metric times the figure by 322. easy and u get the same answer bar .01 much simpler than all the equations
can someone advise how i can attach/upload a spreadsheet as i cant get gas rate calculator to attach
cheers
Dont think you can, but if you up load document to "google docs" then post hyperlink like this:
gas rate calculator
https://docs.google.com/leaf?id=0B6...YzY2ZmIyNjAxNzdi&sort=name&layout=list&num=50
Reply to gas rate calculator in the Plumbing Jobs | The Job-board area at PlumbersForums.net
