Discuss gas rate calculator in the Plumbing Jobs | The Job-board area at PlumbersForums.net
stevetheplumber
Subscribed
BG boys have a gas rate calculator on their laptops you just put in the two readings or time taken and it does all the work anyone know if its available anywhere preferably free?
If you can't find one but can provide the calcs then I can write something.
send me a PM and i will send you a spreadsheet, all you have to do is input the gas used after 2mins or the time taken to burn 1cu3
i photocopied the tables out of my corgi book and laminated them. easier than getting a laptop out. takes no time to find gas rate
there is an app out which is a little cheaper which goes up to u16
its no that difficult. if its an imperial meter divide the amount of secs by 1098 and if metric times the figure by 322. easy and u get the same answer bar .01 much simpler than all the equations
the OP asked for a gas rate calculator NOT a HI calculator, these calcs give HI
just downloaded it on i tues oh yes nice and easy to do gas rates now
i just get out a calculator, its not hard to work out after all!!!!!!!!!!!!!!!!!!!
Same as that. I have been shown various ways to work them out, but that just confuses me. I must admit, if I had a simple app I'd probably use it. Though the maths isn't hard. Trust me, I'm mathematically a moron, and I can do it.
There are spreadsheets that do this and a lot more available on the site PM me and ill send a link
can someone advise how i can attach/upload a spreadsheet as i cant get gas rate calculator to attach
cheers
Reply to gas rate calculator in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Could I ask for some help with a water flow rate problem. I have good mains water pressure on the ground floor. There is no tank in the loft but an unvented cylinder in the upstairs airing cupboard. A gas heat only boiler. Upstairs I have two en suite rooms. One with a shower and one with...
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the cause. I would like a flow rate of about 12L/min. Here is my set-up: Standard gas boiler (not a combi) in the kitchen, have cold water tanks in the...
Essaboy
E
Hi everyone, My customer has a gas fire (Gazco Logic HE fire, about 10 years old). It's a slide control fire. The fire has become difficult to light. One has to push a lot more firmly down on the control slide to get it to light. At which point, all is fine. The pilot is good, new battery...
Just a quick question on common ducts for gas laundry appliances. I have recently looked at a gas ironer which shared a common duct with 2 electric dryers. I believe this isn't allowed but the manufacturer sais it's up to a risk assessment. Any ideas anyone.
Hi all, I’d really appreciate some advice. I’ve just put half a cup full of rubbing alcohol in my laundry draw by mistake - I thought it was my white vinegar. I’ve taken the draw out and got rid of most of it as it hadn’t gone anywhere - unlike the detergent. But am a little weary to continue...
