Discuss Gas pipework test rig? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
macka09
hi folks. What sort of rig do you all use to to air test gas pipework? Cheers
I use something not too dissimilar to this from screwfix
https://www.NoLinkingToThis/p/baile...VqZPtCh1YdgRfEAQYAiABEgKCrvD_BwE&gclsrc=aw.ds
Just hook up my electronic manometer instead of theirs and have an isolator on the pump
This one.
Tyre valve fits into a 15mm comp fitting.
Reply to Gas pipework test rig? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
