Discuss Fitting advice required for 30mm female thread in the USA Plumbers Advice area at PlumbersForums.net
Hello. What fitting do I need to connect an apparent 30mm diameter in/outlet, on a water pump, to 25mm MDPE pipe. It's on a DAB Jetinox 112M. Thanks in advance.
What’s the water mains ? Tank ? Well ?
Its to draw water up from a well. I think 1" bsp male x 25mm mdpe is correct. Thanks very much for the help and replies. Cheers.
[automerge]1586938672[/automerge]
I’d suggest thinking imperial, it’s most likely 1.25inch. In which case I’d expect you need an MDPE 25mm x 1.25inch male adapter
Thanks for the reply.
[automerge]1586938779[/automerge]
Up from a natural water source.
Reply to Fitting advice required for 30mm female thread in the USA Plumbers Advice area at PlumbersForums.net
