- Messages
- 226
hi all
i have a ferroli f30, when i turn the DHW on the led on boiler lights heats water for 90secs or so the led goes out and boiler goes into standby then fires back up and the cycle repeats over.
i have follow the MIs and changed the DHW sensor to no aval
i removed the room sealed cover and run the DHW and it works fine, ive checked the flue for blockages non were found, if i put the cover back on it runs for about 30 seconds and the fault persists, if when it cut out with the cover on it let the cover go slightly it fire back up straight away, if i dont do that it takes a few seconds to fire up.
would i be right in thinking its a faulty air pressure switch or can you guys advise any further as ferroli are close tonite so i carnt ask them
cheers all
cheers all
