Discuss fault codes for ideal icos boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
danielp
hello does anyone know any faults or the codes for this boiler hae looked on the internet but cant find them and its to late to ring ideal ! the codes were lf then changed to h flash then e and alternated between the two thanks
Fault code icos anywhere on the boiler means throw it away and get a real boiler
HOW IN THIS DAY CAN ANYONE PRODUCE A BOILER THAT TOTALS THE BOARD WHEN A FAN FAILS SUFELY A FUSE SOMEWHERE WOULD HAVE SORTED THIS
Turn the fuse spur off for 10 seconds then turn back on and it will hopefully be ok, this is a common clich on icos. If it goes back to "h e " im afraid you will have to replace the pcb ( expensive )
ouch yes it tripped out all the electrics when i turned up it ignited and was thudding on the casing like the poc wernt getting away then displayed h e but didnt have tools as was at a friends late sunday also could smell neat gas coming from it so just isolated it now !
ok yer thanks will try that i was going to go round tonight but went home and my own boiler had failed ! just getting into more breakdowns now
Reply to fault codes for ideal icos boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
