Discuss Empty Water Tank In Attic in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Richarp
Hi All,
i moved into a house a couple of years ago and have decided to board the loft.
I've found any empty water tank that must have been used before an immersion tank was installed but it's still connected to a pipe going into the wall.
Is it ok to remove the tank? If so, what should I do about the pipe?
Any advice gratefully received.
The pipe going out the wall is the over flow, if the tank is disconnected then cut it up with a hand saw and remove.
check any pipes arent live then cut them out and dispose of them.
Am I the only one removing the old tanks these days lol!!!? I always feel its a bit of a shortcut just leaving it up there just because its in the roof space...
if you cant get it through the hatch without cutting, most leave them up there
I always remove them and the wooden stolage.
Reply to Empty Water Tank In Attic in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone, I have a question about adding a second bathroom to a house. My parents house has one bathroom upstairs and the house is all mains...
Hi all I have a problem with my hot water header tank getting warm water into it from the bottom of the header tank (not the hooked...
  • Solved
Hi, I am looking for a bit of advice. Our Gledhill hot water tank was installed incorrectly 18 months ago and has been sending bubbling hot...
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated...
hi all, i need help to fix the leak from a pipe connected to the water pump via flexi pipe and it is feed from the immersion heater. I have...
