Discuss Elnur CMX15 electric boiler vs Vailant Ecotec pro28?Hi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Richie_C
Hi everyone, i really need one of your expertise to clear something up!
which is more powerful out the two?
Obviously the electric is 15Kw maximum and the gas is 28Kw but I have read that electric is 100% efficient and gas combi can vary?
i have a three bedroom semi and want to ditch the old gravity fed system and have combi take over but I want good pressure to have a nice shower etc.
Would the electric provide enough pressure to have a nice shower or would i be better off going with the Vaillant? All running costs aside as I know electricity is deerer.
Depends on the cold flow & pressure into the property. Check the tech specs of each boiler & see which delivers more....I suspect the gas boiler will be better
Ok thanks, what shall I be looking for in particular in the tech specs to compare?
If you have gas then use it. You need to look at the flow and pressures of your incoming water main. How many bathrooms?
Ok is there a pressure guage on the incoming water main or would this be on my boiler?
It's 1 bathroom
You need to measure the flow & pressure coming in - usually easiest to do this at garden tap. Then see what the DHW flow rate is in the specs for a given temperature rise. The figures in the tech specs will assume good flow & pressure coming in. (If you only have 10 l/pm coming in you will never get 12 l/pm out)
Ok thanks all info taken in and appreciated. I can get the cmx15 dirt cheap so that's the reason I'm considering it.
To have a very good shower you would need a more traditional system with water storage of of some variant, showers fed from standard combi boilers have very limited performance
Yes I understand obviously a megaflow would be the best route but that's an expensive option plus it takes up space and I've only one bathroom so probably wouldn't need more than good combi. I suppose it does also depend on what you class as a good shower as I've had a few showers at my friends house who has a Vaillant combi and I really enjoy the shower.
I wonder if the electric ones come with a small 15L integrated tank so it can maybe heat the water slightly before hand?
You will regret going electric when you get your bills. Pay more money up front and have a cheaper system to run in the long run.
Reply to Elnur CMX15 electric boiler vs Vailant Ecotec pro28?Hi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the...
Essaboy
E
I want to swap my electric shower to a power shower. I have a 200 litre pressurised hot water tank in the loft (not a combi boiler) the hot side...
J
Hi all, I'm very new to boilers and would appreciate any advice. I've moved into a new flat (electric only, no gas) that has an old immersion...
Hi, I wonder if anyone can offer any advice/solutions... I have a boiler, a Valient EcoTec 28 pro, which was fitted a year ago. It makes a droning...
N
Hi, i'm looking for some advice on improving the performance of my electric shower as it frequently fluctuates in temperature and flow. The 8.5kw...
