Discuss Does this expansion vessel need supporting? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just noticed this on a job and wondered how dangerous it is if any of you knowledgeable people can tell me if it's supposed to be supported?
Cheers wet bandit
As it’s a small one I would say it’s ok
But wouldn’t harm if you added thr bracket
I think it should be OK, when it fills with water the weight will cause the 22mm to bend but the bottom of the vessel should hit the 54mm header below & not snap it.
or just wrap a bit of wire around the steel above then round the 22mm bend to the vessel job done:D:p
Not the worst job really.
22mm copper will hold a lot.
But I would have wanted it clipped just above the expansion vessel at least
What’s the outcome of it falling off?
What’s it likely to fall on? Assuming it’s 5m high and weighs 5kg if it hit someone on the head you’d expect a serious injury if not a fatality.
If it’s 1m high in an unfrequented area it’s not such an issue.
Always fit equipment as per the manual and then your arse is covered.
Beg to differ old bean.
As a professional you have an obligation to assess. No manual can cover every eventuality so it up to you as the professional to do what is most appropriate using your judgement and experience.
I often ignore MIs because they are not on site in front of the problem and I am.
Each to their own, can of worms me says.
Damage someone/their property and you’ve not met the OEMs requirements the man with the little hammers going to have something to say about it.
You’ve also given the OEM a perfect excuse to worm their way out of any future warranty claim.
Plenty of cases where someone’s done something with the intention of making it safer without understanding the design intent and actually caused problems.
Personally, I prefer to do a job that nobody could come later and do the finger poking at it.
Tbh, we probably all do that at times to other people’s work.
Reply to Does this expansion vessel need supporting? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
  • Sticky
