Discuss disconnect a back boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I
ian260281
hello - I have just bought my first house and wish to drain and disconnect the pipes feeding the backboiler as the chimney breast has recently craked and I need to fit a log burner, therefore digging out the backboiler.
there is a drain tap next to the fire breast.
there is a pipe feeding and returning the HW tank.
if i drain the backboiler next to the fire breast, will the pipes fill back up? I can not find a supply?
would i be right in thinking the system is closed loop, or will it have a fresh water supply which i need to turn off?
I was planning on draining the BB then disconnecting the pipes when i dig the old fire breast out - i will then cap the pipes off. I guess i could do this at the HW tank but there is very little space to get in round the back of the tank.
any advice would be very much appreciated
cheers,
Ian
Sounds like it may be a direct system. The same water will go through the boiler as in the cylinder, fed from the cistern in the loft.
there is a cold water tank directly above the HW tank, this feeds the bottom of the HW tank.
I currently heat the water via immersion.
how do i tell if the BB pipes going into the HW tank are open to feed the boiler or a coil of pipe filled with water only from the BB?
cheers,
ian
If you've only got one tank in the loft it's likely that it will be a direct system. If there is no drain cock on the cylinder it's normally a good indication as well, the drain off will be on the back boiler.
so if i drain it at the BB, it will drain the whole HW tank?
best bet is to drain HW tank, turn off cold supply, cap off the two pipes coming out of the HW tank then fill the HW tank back up?
ian
so i will need some blanking caps to do this? is 21mm the standard for HW?
do these fitting work on a taper to create the seal or do i just tighten them up real good?
ian
Assuming it is a direct system yes. The pipes coming out of the cylinder will normally be 28mm or 1".
The pipes coming out the cylinder will be 22mm or more likely 3/4" as it will have been in a long time
Reply to disconnect a back boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi We have a vented oil-fired heating system with a coal fire back boiler, this is going to be changed to a sealed pressurized system tomorrow and...
J
Hi all, I am a plumber but I do not carry out works to boilers as the majority of my is bathrooms so I am not gas safe. I have completed a...
when I removed the back coal saver I can now see the mental back boiler. I could not see the back boiler when I put the coal saver in place last...
Hi There was no shut off valve on the tank feed to the hot water cylinder, and I needed to move a couple of hot water pipes, so I shut off the...
Hi, I need to drain my vokera 29 boiler in the attic as Im going away for 4 weeks at least to make sure there are no frozen pipes. In my small...
