Discuss Danfoss HSA 3 valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
MZR
hi all
been called to a gloworm ultimate 60ff today with a danfoss hsa3 motorised valve, the hot water works fine the heating when called for the stat says its on but the valve is not moving if i put it on manual then it all works fine but the stat wont switch it off until the valve is moved from manual, ive checked the wiring and found this blue wire from the valve not connected i have no idea where it goes and carnt find the pdf online for the valve i have attached a picture any help would be great the blue wire has red tape on it
What does blue tend to be used for? :wink5:
will it make a difference white/brown not white black as the one in the picture is white brown ? what i carnt get my head round is the hot water works fine on the programmer ? even if the blue wire is neutral hot water still works ? its just the heating wont switch on from the programmer ?
im thinking the brown and white is wrong ? and neutral is just left out ?
what type of valve is it (mid, diverter) ? and tbh mate it might be easier to change the valve for a new one depending on age
Why are the earth wires going to the grey wire on the zone valve? I think this needs to be stripped out and redone properly
3 core flex least it identified as lives
ive been told another plumber was out a few weeks ago and changed the zone valve
did it work after my thoughts no
mid position standard
blue netural
brown and white heating call
orange hot water call
grey hot water satisfied
i am crap with the wires on the terminal blocks just looks like a birds nest, what am i looking for to add the brown and white too ? would it go to the programmer ? sorry for the lame questions or where should it be going ?
black wire
Blue is a neutral
Brown/white goes in with ch on or return from room stat if there is one
Orange goes in with hw off and sat from stat
Grey goes in with pump boiler and cyl stat call
Reply to Danfoss HSA 3 valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
