Discuss Cross bonding cutting gas/water pipes in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Matt0029
I know no one really does. But technically why should we use bonding clamps when we cut a section of gas or water pipes out? Thanks.
To stop it sparking if it’s a better earth than the house electrics
Cutting the pipe can cause a small spark?
Yes if current is being passed to earth via it as the steel / copper pipe in contact with ground has a better / lower resistance than the main earth / house lost the main earth
@Murdoch can you explain it better ?
It can actually throw you across the room!
If there is a short that is running to earth through the water.gas pipe and you cut this pipe - at some point of the cut , you become the best path to earth and get the full current running through you!
By clamping either side of your cut you provide a lower resistance path for the short to carry on through the pipe to earth (via the clamp wire) - rather than via your body.
Reply to Cross bonding cutting gas/water pipes in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi everyone, How do you know if there is a cross over with the pluming system in flat? All pipe work under sink, bathroom etc in the flat itself...
We have an old gas pipe in the understairs cupboard. The previous occupants had the gas meter moved, but this old pipe remained. This pipe goes...
Sonya K
Hi, Non-professional / knowledgeable person here. I'm a Brit in Romania who volunteers for a charity building an old peoples home for needy old...
