Discuss Concealed cistern fill valve. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Matt0029
Has anyone got an idea what make concealed cistern this maybe? I need a new full valve for it. Thanks
Just looks like a stnd inlet valve maybe a Thomas Dudley fill valve might fit etc
Edit it’s a cera/ siamp frame
Yes and yes you can pull it out and tighten the flex on the just nip up the retaining nut
1/2 by 3/8 probably
Yes ball valve end should be 1/2
Thanks what's happening with it is. Flush the toilet. It flushes water stops flowing in to bowl. It then starts flowing in to bowl as the fill valve isn't shutting off. It will stop for some reason if pressure the small button on the flush plate. Strange!
So anyone know what the blue but is sticking out if the thread? Worried this would effect the Flexi sealing?
It pushes in further / cut it off it’s a strainer / flow limiter and yes iso valve normally ok
Any idea why it just fills and won't stop. I presume this is a washer or problem with the arm. But then why it stops when the small flush button is pushed. Unless it's jolting it to shut it off.
Reply to Concealed cistern fill valve. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
With a toilet fit to a concealed cistern vanity were the front panel slides up if you need access it at later date and fitting Is it advisable to...
I have a cloak room that has a width of 1035mm that I am wanting to put a combined concealed toilet and vanity in. I was looking at a 550mm...
J
Any advice as to how to install a Dudley concealed cistern toilet lever? The pack has three nuts but no instructions as to where they go.
Are these connectors any good that come with the fluidmaster concealed cistern they seem to move still when tight. Thanks
I have a vanity basin and concealed cistern toilet to install. In place if a wall hung basin and toilet in a down stairs cloak room. The only...
