Discuss Compression Joint Query in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
bulltaurus
Trying to add a bidet shower hose to my toilet. Am stuck at the joint as to what I would require to join the tee compression with the toilet tank. I have seen in you tube videos that the copper pipe slides in the tee compression hole but I got a piece of copper pipe and it just doesn't go in the hole for tee compression hole. Any suggestions welcome
Image posted here
https://www.flickr.com/photos/65231752@N00/16973879803/in/dateposted-public/
You're not allowed to connect a bidet type hose to the cold water system - its against the Water Regulations as there is nothing to prevent back-flow into the rest of the system. In any case, you would appear to be out of your depth in what you are attempting.
As the above.
Please register with us to receive additional answers to your problem.
Reply to Compression Joint Query in the Plumbing Jobs | The Job-board area at PlumbersForums.net
