Discuss Communal Heating System - radiator and water not hot in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
catflapuk
Hello,
I live in apartment with communal heating system and have heat interface unit in my flat. From one day to another all radiators are not getting as hot was they used to and I have noticed the same with the water. I am clueless as to what the problem could be. Is it the HIU or the communal system that may have a fault? How can I find out?
Reply to Communal Heating System - radiator and water not hot in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied...
Hello all, I live in a flat that has communal heating through a single pipe system. I recently had replaced a deco flat panel (waffle) radiator...
Hi all, Our flat has communal heating and our thermostat is set so low so the heating should never be coming on. However over the last 10...
M
Hi all, I live in an old building with a communal boiler and central heating. The communal boiler is located in a small plant room and serves 8...
MLondon
M
I have had a problem where 2 downstair radiators are not heating up the same as the rest of the radiators around the house, now previously i had...
