Discuss Cold rads but water tank hot - Possible causes? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
hoppyfrog
Glowworm Micron 80FF boiler, boiler fires up (for very short periods, a few seconds) but does not heat the radiators but it heats the hot water tank. What could the possible problem be?
Could be several things:
Programmer/Timer
Room thermostat
Motorized valve
It's a case of checking each one.
Do you have a multimeter (and know how to use it)?
Programmer/Timer
Room thermostat
Motorized valve
I dont have a multimeter but I can get one and figure out how to use it. So I need to check the three things you've listed to see if they're dead? I've currently got a guy on site doing a powerflush so I can use him to help me figure things out, he doesnt troubleshoot boilers but he's been helpful.
Be very careful. You will be measuring AC voltages - about 240Vac - which can give you a nasty shock.
All the components hopefully wire into a single junction box, aka wiring centre.
If you tell me how many motorized valves you have, and which type, I can give you more instructions.
we should not encourage any incompetent person to cary on work with electrics or gas !!!!
OP pleas call a local heating engineer to sort out your problem
I'm not incompetent Mr safegasinstall !
Anyway, I had a powerflush done today, and afterwards the system started working again. V strange.
Not incompetent? And yet you will have to figure out how to use a multimeter....
If it walks like a duck and quacks like a duck........
Thread closed.
And doitmyself. Check the OP's competence before offering advice in future or you and I will fall out!
Reply to Cold rads but water tank hot - Possible causes? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a 2 pump hot water tank (Flomax 180L fitted in '94) in airing cupboard system with an Ideal classic boiler (downstairs next to an external...
I live in an apartment with a cold water tank. The cold water tank feeds the cold water tap in the sink and the bath. Recently, I refurbished my...
  • Solved
Hi, I am looking for a bit of advice. Our Gledhill hot water tank was installed incorrectly 18 months ago and has been sending bubbling hot...
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated...
