Discuss Cold rads but water tank hot - Possible causes? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
hoppyfrog
Glowworm Micron 80FF boiler, boiler fires up (for very short periods, a few seconds) but does not heat the radiators but it heats the hot water tank. What could the possible problem be?
Could be several things:
Programmer/Timer
Room thermostat
Motorized valve
It's a case of checking each one.
Do you have a multimeter (and know how to use it)?
Programmer/Timer
Room thermostat
Motorized valve
I dont have a multimeter but I can get one and figure out how to use it. So I need to check the three things you've listed to see if they're dead? I've currently got a guy on site doing a powerflush so I can use him to help me figure things out, he doesnt troubleshoot boilers but he's been helpful.
Be very careful. You will be measuring AC voltages - about 240Vac - which can give you a nasty shock.
All the components hopefully wire into a single junction box, aka wiring centre.
If you tell me how many motorized valves you have, and which type, I can give you more instructions.
we should not encourage any incompetent person to cary on work with electrics or gas !!!!
OP pleas call a local heating engineer to sort out your problem
I'm not incompetent Mr safegasinstall !
Anyway, I had a powerflush done today, and afterwards the system started working again. V strange.
Not incompetent? And yet you will have to figure out how to use a multimeter....
If it walks like a duck and quacks like a duck........
Thread closed.
And doitmyself. Check the OP's competence before offering advice in future or you and I will fall out!
Reply to Cold rads but water tank hot - Possible causes? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
