Discuss Cold Radiators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Yes as a TRV may still pass when screwed right down. Without having a 2nd beady eye on what this guy has done you may never know as he could just keep trying to pull the wool over your eyes :(
Me thinks it's not that daft, there are 5 rads not getting hot, that means he's done it five times, he would then be the real plumber from hell, too much speculation going on an not enough facts, I will sort it out next week chaps and I will report back, it will not be just one thing wrong. leave this one alone now and I will be back.
Tony
Sorry just getting in on this coz I love a mystery
What do you think it might be Riley???? we could have a met,:21: throw a party :cake: play cluedo :beatnik: or simply have a cuppa:coffee: I will let you know don't worry.
Tony
Make sure there is not a uncontrolled by pass
SafeGasInstaller,
I have a bit of kit that sits on the pipe and measure the flow inside, I will spot the uncontrolled or controlled bypass in a flash, I don't want to worry about me either, I have been in the trade for the 55 years and as long as the Good Lord doesn't take me in my sleep before I go to site next week, I will sort the plumber from hell out, be assured, trust me I am a real plumber!!!:35:
BTW I have heard they are going to officially make plumbing a trade next week :lol:
Anyway do any of you know when plastic tube was first used for minibore central heating???
SafeGasInstaller,
Jesus this is like a plumbers version of Eastenders... Loving it
Have you been back yet Happyflyer? If not when?
Just to chuck my 2 pennies piece. When that plumber left did he jump in a van or ride off into the sunset!!!!
Tommy
Me as done, put the old trusty test kit on and found the water flow was too low, lots of other things need to be put right boiler in the roof space, with two zone valves pipe to valves go up higher than boiler so boiler is not the highest part of the system so auto air vent in boiler not much use, got plumber back, programmed boiler to run pump at full speed, twas only running at half, closed down ABV and got water flow up to boiler recommended rate, all rads now (WOW) get hot except on on new index circuit, balancing now tight, main F/R in roof space rises up to where it drops down to Ist floor needs 2 AAV and pipe cutting shorter, needs two AAV on boiler end zone valve branches, you need to remember that the Valliant like others don't have a big pump on 20 Kpa this is not very much for long runs of 15 mm tube, If I was fitting a boiler which feeds heating and a Magaflow I would use a basic boiler without pump, you can then change the pump if you drop a clanger.
Tony
PS the plumber who did the job now calls me Dad and I will take him under my wing from now on, why because he listened, the day you stop learning is the day you die and that includes me.
Rock on Tommy
Fair play to him for not getting his back up.
I'm impressed too.
Whats the test kit? Sounds like a nice toy to play with.
I've never thought about fitting a boiler with out a pump. Every day is a school day and I've just learnt something.
Reply to Cold Radiators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Sorry if question already answered in previous posts, but I can't find a solution to the below: We recently moved house to a new home that...
Oil boiler (now~15 years old) unvented system with 17 radiators. We moved in 5 years ago and I had to keep bleeding the same radiator. The bleed...
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was...
Hi - I'm a reasonably experienced DIY plumber but just can't work out why the last new rad I've installed is cold - would really appreciate your...
O
Hi All, We renovated our house in 2019 and put in completely new plumbing system and piping including new boiler and 9 radiators. Off those...
