Discuss Central heating f4 leak sealer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Something else on my mind -
We have been fixing leaks on sealed heating systems by using fernox f4 leak sealer, I was involved in an debate (friendly) that it might stop the leak temporarily but after about a year, or if the system gets emptied that the leak sealer what ever it does will not work anymore ie just consider it a medium term fix as theres no short cut to finding the leak.
Other plumbers say it will be a permanent fix.
Any opinions?
Thanks again
Readingplumber
and it does void warranty conditions with some manufacturers. best to find the leak and fix it properly imo.
It fixed a pressure drop for me recently! It lasted about 24 hours then it started to leak again! I think the leak was too big for it to be honest!
After taking up the laminate & floorboards beneath managed to find a leaking plastic push fit isolation valve!
So I don't rate the leak sealers much, plus I have seen if vents completely filled with jelly like substance after leak sealer added! So much for "does not block air vents"
Always better to look for the leak. I don't use leak sealer at all... can cause other issues clogging up the system and not worth the hassle.
i only use it if the sealed system is losing pressure over 3-4 months making the leak impossible to find, ive never had to add any more later on though
As AW said can void warrentys on new boiler due to the small passage ways on the new heat exchangers
wont worry an intergas boiler then, used leak sealer on pinhole leaks in buried pipe, saved digging the floor up for the timebeing.
Reply to Central heating f4 leak sealer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, I have a WorcesterBosch Greenstar 42CDi classic combi, which is providing DHW fine, but not heating. Was working fine in spring...
1K
Hi. I'm having some issues with my boiler / central heating and have enlisted a local 'Combi Heating Specialist' to sort it out but he seems to be...
3K
Hi, new to this forum. I hope someone experienced out there can help me find the fix. We recently finished a building project and had a major...
2K
Hi everyone, About a year ago we moved into a new property which has a towel heater as part of the Central Heating System. There are no...
1K
My boiler started to lose pressure once a day about a week ago. It is now losing pressure very quickly and goes from 1.5 bar to empty in an hour...
2K
