Discuss Capping steel gas pipe buried in concrete in the Plumbing Jobs | The Job-board area at PlumbersForums.net
pauland
Our Gas guy has detected a leak and using a sniffer, the leak seems to come from a section of buried pipe.
This pipe is made from steel and we could probably get by capping off the pipe at or near a "T" junction ( removing the leaking pipe from the buried network ).
The Gas guy has suggested that it's not possible to cut the pipe and then cap it, but we'll need to unscrew the pipe from the T junction and put a cap in place of the pipe.
As you can imagine, access is going to be very tight - I'm wondering if it's even going to be possible to unscrew the pipe at all.
If the pipe cannot be capped off, we have a major job - rerouting gas pipe to the kitchen and living room.
I may end up digging channels in the kitchen floor to allow new pipe to be laid and it's not a task I'm looking forward to.
Anyone managed to cap a pipe in similar circumstances?
(Before anyone asks, I'm up for the donkey work, I'm just trying to make the Gas guy's job as easy as possible ).
I do trust him, it doesn't mean someone has a great idea, or some suggestion that turns a nightmare job into a simpler one.
if he can't get to the T , get him to cut pipe , re thread , then cap
How on earth will you thread onto a buried pipe. Probably easier to cut grind and weld a plate on. But that's just stupid if you can get to a tee and thread in a plug.
Theres a thing called digging ,
You need to dig enough out to get a power head on but your average Joe plumber won't have one so best to cut it with a recip unscrew the cut and plug
That's a big hole in a concrete floor. Pipe 40mm down, the the cutter add on another 125mm so u can get in square. Loads of fun.
Tool station sell hand ones ,
Thanks guys for all the comments.
I managed to dig out enough concrete for the gas guy to be able to cut the steel pipe with a reciprocating saw. He then put a blowtorch onto the screw joint at a T junction and much to my surprise he was able to twist out the pipe.
He then capped off the T joint and tested the system for leaks - there were none. He then put in a new section of brass pipe from the T joint, partially below the concrete. He wrapped that in tape.
So, for a job I thought could be a nightmare, it went quite smoothly.
Generally the pipe looked in reasonable shape, but as it moved from the T junction it became quite corroded. I think it's no surprise since the concrete wasn't as dense in one part of the floor and we've had a washing machine and dishwasher in that spot with various spills and thrills.
Anyway, one month from getting the gas cut off, we're warm again.
Thanks guys.
Reply to Capping steel gas pipe buried in concrete in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys, first post here So I have been boxing in a number of heating pipes that are throughout my garage since the boiler was located there by...
Morning. I have a leak. It’s coming from the connector pipe….the picture shows the pipe. It is a cold water pipe going in to the back of my...
We have an old gas pipe in the understairs cupboard. The previous occupants had the gas meter moved, but this old pipe remained. This pipe goes...
Hi Some people (not plumbers) have advised me that it's not such a good idea to a) Have 4 x 90deg bends in a sewer pipe and b) Encase these pipes...
