Discuss Can anyone tell me the proper name for this? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
Larington
its all 22mm
Can't see a check valve on it but looks like a composite valve for an unvented cylinder.
Composite, was the word I was missing. Trying to order it from cities at 4:55 from site and just couldnt think of the word. "You know... for an unvented cylinder with the 8bar expansion relief.
Heatrae Sadia combination one I would believe when I order one tomorrow, anyone have a disagreement with that? Thanks for the help
are you g3 registered ?
No. Passing the job on to someone who is, but just trying to get all the info.
well why are trying to ordering parts ????? if your not doing the job
Never got to do this before firm with my apprenticeship went caput. Also never got to go from there onto gas.
Job is For a friend when he said he had a leak. I went out to it. Said I couldn't do it as its unvented and not allowed under doc g but will help as best I can. Hence here now.
the best advice you could give him is get a g3 plumber out and looks like its been leaking for a long while
Yeah has been, lot a heavy staining. He said he just hasn't noticed, drips straight through boards into open cavity.
I think we may be missing what I've said/mean, when I saw it was unvented, I have left it alone but calling out someone who can but want to help as much as I could. Not worth touching it as not carded to and obviously any issues PL insurance will say jog on. Just not worth it.
Reply to Can anyone tell me the proper name for this? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone please tell me where I might purchase a 90° bend 15mm x 22mm Isolating Valve Thanks and Regards. Hugh
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
I have recently moved house.it appears the shower drain has become blocked and there is no inner cup to remove and clean. I believe the waste is a...
I have a slow leak in the bath. Its a mixer type set up. I'm unfamiliar with the tap handles and how to access the cartridges etc. If I can work...
