StuWalker
Hi Guys
Im sorry to say I have strayed from the flock and have left the great profession of plumbing and am now running a company in the hire industry, its the same $h!t but a without a drain to pump it in to
We have been asked to supply our existing LPG shower blocks for an indoor job in December, which means I have the small problem of heating the water, as we cannot run the gas indoors!
There will be 6 blocks of 4 showers which I want to daisy chain from a direct heating system (plant room) which we will build in a trailer, the trailer will house the cylinders, pumps and expansion vessels. We will then run the circulated hot water to the shower blocks. Each shower runs at either 4 or 6 litres a minute.
The current set up has blending valves off of a gas water heater feeding water to the showers at 37/38 Degrees, and the question I would have is, do we connect 60 degree flow from the cylinders to the current blending valves or do we cut them out of the equation and run a constant 40 from the plant room on a circulating loop?
If we do either way, what size cylinders will we require?
What size pump to ensure there is constant heat at the heads or the blending valves?
Will we need to pressurise the system to ensure there is no loss at the shower heads if they are all used at the same time?
No doubt there will now be an influx of questions which I will answer once I get back from the school run
Thanks in advance
Stuart
Thanks in advance
Stuart
