Discuss Building Regs Part L in the Plumbing Jobs | The Job-board area at PlumbersForums.net
JAH HEATING
This covers controls to a heating system doesn't it ? Stats, valves etc ?
thanks
A system with no by-pass, all TRV's is not Parl Compliant then ?
No stats in property the same ?
Cheers
boiler got inbuilt bypass? and yes no room stats fail on part l
Nope, non compliant.
I've just been working on one today.
Told customer he should have room stat fitted, answer was, we will only turn it up full anyway and I'm not paying for it.
What can you do ?
I will send him a letter/notice telling him what the rules are but what else is there. .?
All trvs is a fail aswell isn't it 10 per cent required of heating load aswell as boiler bypass
depending on size of system under 15 rads your fine
and just going into it not many these days heat only boilers have pump overrun / can be run without one
and must combis only have a pump over run of a couple of mins no way going to dissipate much heat to a rad
and if all trvs close which is very rare as most ive seen are left on anywhere from 3-5 (setting) you have under floor heating :D
Reply to Building Regs Part L in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi , recently moved into a DWH Barrett home , 3 bed house . The heating is zoned but in one bedroom only upstairs with the other bedrooms...
Flue Snugs Hello all new member here. Flue snugs. I’m seeing a lot of boiler installs on you tube that don’t have flue snugs to comply with...
I have a 40 year old floor standing Glow Worm 45-60 boiler (open vent )which is in a cupboard in the centre of the house. Its an old workhouse...
