Discuss Broken air bleed valve has gone into radiator in the USA area at PlumbersForums.net
Is this a problem that a section of air bleed screw is rattling around in the radiator
Yes depending on where it ends up; blocking a valve or scoring a valve seat so that it won’t shut off properly, blockings waterway in the boiler etcetc.
Best to remove the rad and flush it out.
Rad is off and flushed it but it won’t come out- it’s a myson round top radiator, it’s the thread to the nut and bleed valve probably 6mm in diameter
Reply to Broken air bleed valve has gone into radiator in the USA area at PlumbersForums.net
  • Sticky
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
