- Messages
- 34,358
- Solutions
- 2
just a heads up had a bad batch of Bristan exchos hot passing through the cartridge
Test before you leave your merchants
Discuss .....Bristan Echo..... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Another heads up. Had a few Bristan non returns getting stuck in the hot and not letting water through.
1 gravity/2 combi.Gravity ?
What you thinking?
WillI’ve had it on gravity hot mains cold
Open the hot tap first then the cold find the cold shuts / forces / puts pressure on the hot nrv
And when you try opening the hot again nothing
Find giving the hot nrv a little smear of silicon grease helps a lot
I thought that, but there range is amazing.I aint far off sacking off Bristan
That might explain the drop in quality of heritage bathroom products then. Had a few complaints with the last couple of bathrooms I've doneNow Bristan are no longer buying from diff chinese manus but making themselves. It will only get worse as the accountants squeeze ever harder...
Reply to .....Bristan Echo..... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
