Discuss .....Bristan Echo..... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
ShaunCorbs
Super Moderator
Staff member
S. Mod
Subscribed
Solutions
just a heads up had a bad batch of Bristan exchos hot passing through the cartridge
Test before you leave your merchants
What you thinking?
I’ve had it on gravity hot mains cold
Open the hot tap first then the cold find the cold shuts / forces / puts pressure on the hot nrv
And when you try opening the hot again nothing
Find giving the hot nrv a little smear of silicon grease helps a lot
Reply to .....Bristan Echo..... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
PSxxxxxx
