Discuss Boiler problems in new house! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
doddym
Hello,
Ive just moved into a new house which has an older boiler installed.
It is a Glowworm Ultimate with a Lifestyle LP112 programmer.
I cannot get the central heating to switch on by itself, it will only operate if the hot water is also switched on at the same time.
If i switch on the central heating by itself the boiler does not even attempt to start or fire up.
The hot water always fires up first time - no probs there.
There does not appear to be a 'y' valve in the airing cupboard.
There are four pipes going in/out of the boiler.
Any advice would be most appreciated
TIA
Doddym
The pump is upstairs in the airing cupboard (hotpress) It works fine aslong as the hot water is switched on too.
ok under the pump there should be 2 gray boxes on the pipes these are motorized valves one is for heat other for hot water is this true??
Definately sounds like a controls issue. Very difficult to diagnose without actually looking at it.
Hi Diesal,
difficult to see, but it looks like a std pump with pipe in one side, out the other & a power cable going to a fused spur. I can't see any grey boxes on the pipes. Its v low to the airing cupboard floor partially hidden by a shower pump.
ok maye have a look for them motorised valves sounds to me like you have a faulty valve on the heating if u find it theres a black arm on top of the valve flick that over to manual and it will fire your heating up.
power go from, time clock>room stat>motorised valve>boiler
and you have clock>room stat>????
we know your boiler is ok as it works on hw
all signs point to a faulty motorized valve
if you flick the arm on the MV you have to manually reset it or your heating will stay on.
keep us posted
Hello,
TIA
Doddym
Gravity HW thats why you can only have HW and heating at the same time. Thats why no 3 port valve.
If you mean there are four water pipes connected to the boiler (or three plus the gas pipe), you have a pumped heating/gravity hot water system. Which explains why you do not have a Y-plan valve.
With this type of system you cannot have the heating on without having the water on. In the summer, you can have just the water on.
If you remove the timer from the backplate, you will see a switch on the back. It's probably in the P position; it should be in the G position.
If you want separate control of CH and HW, you will have to either put a valve into the return pipe from HW cylinder to boiler, or convert it to a Y Plan system.
Reply to Boiler problems in new house! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
