Discuss Boiler issue - cant increase pressures in the Central Heating Forum area at PlumbersForums.net
You have water through your hot taps ?
We have a potterton apollo boiler and it's showing a E1 fault due to a drop in pressure.
Normally I just pull down the green lever inside to increase the pressure but zilch is happening when I do this.
Any suggestions?
That green lever isn’t something I’m familiar wit, it looks a little like a pressure relief valve. It also looks like you may have an external filling loop connection setup as well?
Yes on the front, it's analogue.Is there an analogue (non digital) pressure gauge anywhere on the boiler?
Ok, before you attach the loop, has the analogue gauge dropped?Yes on the front, it's analogue.
I have the filler loop still, is there a way to bypass the green lever?
Reply to Boiler issue - cant increase pressures in the Central Heating Forum area at PlumbersForums.net
