Discuss Boiler issue - cant increase pressures in the Central Heating Forum area at PlumbersForums.net
We have a potterton apollo boiler and it's showing a E1 fault due to a drop in pressure.
Normally I just pull down the green lever inside to increase the pressure but zilch is happening when I do this.
Any suggestions?
You have water through your hot taps ?
That green lever isn’t something I’m familiar wit, it looks a little like a pressure relief valve. It also looks like you may have an external filling loop connection setup as well?
Any suggestions?
The Baxi guy told me this replaced the filling loop, so I'm not sure. They changed it about 2 years ago.
There not that good they do stick / fail
Reply to Boiler issue - cant increase pressures in the Central Heating Forum area at PlumbersForums.net
I have done pressure test for 2" high pressure pipe line by closing the pipe with rubber plugs at the ends. It was 3 bar and I kept it for 24...
