Discuss blow torch flame disorientated in the Plumbing Jobs | The Job-board area at PlumbersForums.net
they flame on my blow torch has gone totally disorientated it has occasionally done his when I have had some solder drop in the nozzle. Once this was removed it has been ok. But now the flame is disorientated even though the nozzle that you can unscrew is clear. Any thoughts on what's going on?
As the Cropster says
Take it off and put it in the flame of another to burn the flux/crap out of it
Always works for me
take the jet out and leave it soak in vinegar,that should sort it
mine went today same, had to get piper-alpha out the van( the t2000) set fire to customers dust sheet when fitting fell on it ;)
my regulars a burnzomatic quickfire with plastic knob to turn gas on, think its come off spindle and overgassing or the air flows blocked.?
Could changing the jet be an option? I have a spare one that came when I bought a spare burner nozzle
Reply to blow torch flame disorientated in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a customers trianco burner that starts from cold ok for a few minutes (say 3minutes) then locks out then will not stay on. Boiler had not...
I am generally a decent handyman, can usually make 2+2=4 and take care of most things to avoid troubling experts with just the basics, but know...
Hi Folks, I have a challenge with a Main Eco Elite 30 Combi which is short cycling on the CH. Water works fine. As soon as you have call for...
I have a Vaillant ecotec plus 831 (one with small circle buttons) and it has passed gas service not long ago. However, the problem I have is when...
2K
Good Afternoon all, I am hopeful someone may be able to offer some guidance on the following. In the home we have a gas boiler (serviced...
