Discuss Best plastic/MLCP pipe cutter? in the Plumbing Tools area at PlumbersForums.net
Doesn't look like they make it anymore.
I've had the JG speedfit pipe cutter for years, it's quite uwell made and the blade has remained sharp but I'd opt for the ratchet type like Rothy's or RS.
Had these for twenty years, never let me down yet, obviously they will explode in a mass of springs and screws now...
Still make'em but no longer with a metal case I suspect...
Am I being a div, it says suitable for multilayer tubing but not suitable for multilayer tubing?
Tbh all cutters are usable on mlcp just some the blades wear out faster I would always give it a twist first and then cut
Reply to Best plastic/MLCP pipe cutter? in the Plumbing Tools area at PlumbersForums.net
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
