H
Discuss Begineers Help - Make of Tap? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
doesn't look like one I recognise, Others on here may be able to help you out on that but if you are able to be locally isolate It I would isolate both hot and cold and take the cartridge out and down to a decent plumbers merchant they should be able to sort you out
From my experiance over the years I find just replacing the whole tap is easier as I have spent many hours emailing tap manufacturers trying to find out if I can get the cartridges.
Isolate the tap and take a cartridge out, it may have information about the manufacturers marked on it.
I have replaced cartridges in a tap very similar to this. It was a Hansgrohe Axor Stark but I am sure I found the name on the tap itself. Check it out for yourself, I don't want to mislead you and cost you money buying the wrong item.
Reply to Begineers Help - Make of Tap? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
