Discuss Baxi combi boiler leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
2fat2slow
Hi All,
my issue on boiler..I noticed that my Baxi combi boiler leaking, i took a picture of issue, please take a look at it;
few more things to mention - that black part above leak, makes regular ticking noise.
should be i worried that much - as to call engineer ASAP regarding this? People please advice, as fixing boiler usually means "expensive" - maybe this is simple enough fix?
Regards
2fat2slow
You have already broken the law by removing the cover mate so it's time to get a Gas Safe engineer out. Looks a relatively simple fix but please don't think we're all "expensive" most will charge the going rate to run a business
Thank your for your answer - i will do that.
Regards
2fat2slow
You need to call someone asap as the part that is leaking can also damage the black unit above it, small leaks if left for to long can start to cause a lot more problems, Get more than one price to do repair, you can even call Glow-Worm for a fixed price repair, sometimes more cost effective if more than one part faulty.
Sorry meant to say BAXI but problems with Forum wont let me edit out mistake
theres 2 comon leaks in there, not that expensive perhaps part cost x 2
Reply to Baxi combi boiler leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello everyone i have a Baxi 424 combi the system working fine but the maximum tempruter on the screen reach only 57 degrees for heater and 51...
I have a "Firebird Envirogreen Condensing Combi Oil Boiler 26kW" a part has went and I can't find it anywhere, I was at every plumbers merchant...
Dear professionals, could someone kindly advise on per below issue, please let me know if more pictures or details needed. I think my Auto Air...
Good evening, I'd like your opinion on something that is worrying me please: my landlady's plumber replaced the bottom/night element of my...
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the...
