Discuss Baxi Burnall with back boiler connection to Unvented /Mains pressure water tank ?? in the USA area at PlumbersForums.net
I have a Baxi Burnall open fire with wrap round back boiler connected via a Dunsley Baker Neutaliser to the vented hot water tank.
I wish to update my older vented system to an unvented twin coil indirect water tank with two immersion slots. I want to use one immersion slot for my recently installed solar panel power input and the second immersion slot as a mains power standard for back up if and when required. Switching to an unvented/ mains pressure system also allows me to do away with a troublesome shower pump (not enough head & each time I use the shower I need to lower the shower head until the pump kicks in). My central heating is a standard oil-fired boiler which would use the primary coil. So far so good - straight forward enough, I think. ......................
However, can I connect my Baxi Burnall with back boiler to am unvented/ mains pressure system with indirect twin coils ??
Reply to Baxi Burnall with back boiler connection to Unvented /Mains pressure water tank ?? in the USA area at PlumbersForums.net
Hi, We have a large Heatrea Sadia unvented hot water tank, not sure of the size in liters but its about 1600mm tall. The tank is around 3 years...
First post as I can not figure this one out. I have a hot water boiler heating system, gas fired, with an HTP SuperStor indirect hot water tank...
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
Hi, We moved into a new property yesterday and are a little baffled by the heating/water tank situation. The previous owners unhelpfully left any...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
