Discuss Baxi 105he secondary heat exchanger in the Plumbing Jobs | The Job-board area at PlumbersForums.net
yes you can piece of cake, just buy the front cover assembly,you need 1 new oring to go into the main hex lubricate it with silicone grease
no, not by the sounds of it have you ordered the round ally part?I've ordered the naked heat x , have I ordered the wrong part.
thats the right oneJust the naked heat x, aparantly you can buy it. Two different ways. I've ordered this one.
[DLMURL="http://www.gas-spares.co.uk/Catalogue/XX-EXTRA-SPARES-all-makes/XTRA-SPARES-BAXI-BA-Baxi-Valor-OR-Broag/HEAT-EXCHANGER-ONLY-SECONDARY"]HEAT EXCHANGER ONLY SECONDARY - Gas Appliance Spares (Preston) Ltd[/DLMURL]
your thinking of a plate heat,the hex in this post is a condensing version,and no i would not recommend using industrial costic soda,if remnants off it get in the boiler or on your skin there will be lots of tears IMHO filling it in vinegars quite good but slowI know by asking this question I'm changing the topic but has anyone tried to clean a secondary heater exchange using industrial caustic soda ? The guy I did my training with uses that.
flow hot in dhw mode? dv or plate if not check dhw ntc resistance 11k reducing with tempI was about to post a thread about a Baxi 105e. I've got a customer who talks a lot (and left me a bit confused).
His complaint was that his water is hot, cold, hot cold.
I checked it out and basically the boiler temp is rising 30,40,50,60,70...gets to 80. Switches off and then starts again.
I figured dodgy divertor valve, but when I mentioned this to the customer he said he had the diaphrams changed last year by another engineer. So now I'm thinking blocked heat exchanger. I checked the filter on the return and it was clean as a whistle. I'm pretty sure it's a circulation issue. Anyone come across this. I can hear it kettling just before it shuts off.
I couldn't hang around at this blokes place as I had an appointment with the accountant. This was last week, and I haven't been back in touch with him since!
Sorry if I've hijacked this post.
Reply to Baxi 105he secondary heat exchanger in the Plumbing Jobs | The Job-board area at PlumbersForums.net
