Discuss Baxi 105HE Problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
markmajor
Hello
It could probablt take all night to type the different issues i have had/having with this boiler but the most pressing on is a Flame Faliure light. It can be reset but i can hear ignition going but nothing happens and the light come on again.
Now this ONLY works for the central heating! If i turn the dial to water only, i can hot water no problem. Seems strange that it will light for the water and not the heating.
Done soem research and can see from various sources,including the hand book, that it may be a blocked condensate drain. Unfortunatley i cant see any instructions on how to fix it. Would it be a call out to someone qualified or maybe something i can do myself?
thanks
Hello and welcome to the forum.
Definitely it has to be a job for a gas qualified person. You cannot work on a gas boiler.
Simon beat me to it.
As above.
Sorry and all that but it's your safety we're concerned with at the end of the day!
Reply to Baxi 105HE Problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Heating and hot water is not working. Plenty of heating oil. I have replaced batteries in thermostat and it seems to be working ok, showing flame...
I am having a problem with my main 24he boiler where the flame is constantly clicking on and off with the heating and when using hot water. Some...
J
Hello, I have a Bosch 35CDi, and today found all the lights flashing on the front. Normally I can reset the boiler, but this did not work. There...
Deleted member 120897
So a strange conundrum regarding water temp if anyone can help resolve, would be much appreciated. Ive tried to give as much info as possible to...
