Discuss assistancee required please guys in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I
iguanamark
Afternoon guys,
have an issue at the present, wondering if you can give me some advice to see which way to proceed.
My father-in-law got me a boiler change (BBU-Combi) in Surrey, and I live in Devon. When I got to the job, I opened up the mains cold water & felt there was enough pressure (no pressure gauge used). I changed the boiler & after the job I got a call from the customer saying the COLD water dropped in pressure when 2 taps were open. I asked my FIL to go back & check it out. He mentioned to the customer that the lead incoming pipe may be furred up, therefore, get a new 25mm alkathyene pipe installed & maybe get the water board to check the pressure. They got the new 25mm pipe in, however, pressure still drops dramatically when 2x cold taps open. The water board were supposed to come in last Wednesday just gone, however, customer has not been back to me whether they have been or not.
Customer threatening to take me to the small claims court, because she says she has been given an inadequate & ineffective boiler (Vaillant Ecotect Plus 831), for which I have explained that is not the case. She had a gravity-fed system before hand, which never had an issue with lack of pressure, to which I explained the differences in systems.
As it stands at the minute, the 25mm comes into the house, about 10inches, before dropping down to 15mm, before going about 2mtrs to boiler & another 3mtrs to bath & basin.
I can't see that there's anything obviously wrong, so just wondered if anyone has had anything like this before, whether it be dealing with customer like this, or an issue on incoming pressures.
Thanks in advance,
Mark
You really need to check flow and pressure before installing a combi or an unvented cylinder IMHO
Unfortunately pal, you didn't do the checks so its on your head really, some places just have bad mains. There's streets round here where everyone has gravity systems cos of the poor mains pressure/flow.
Maybe a small booster such as the salamander would do the trick.
Take 22 to boiler and then split to basin etc after. May help a little but as others have said...
Basic check would be at the cold sink tap, did you open the tap fully. did you check the stopcock in the street and house is fully open? After that put a guage on the main to check the pressure. Do any of the neighbours have combis?
you been twice and not checked the flow rate?
looks like you will have to install a 200 gal cold feed tank then to feed the cold taps to the bathroom keeping the kitchen tap on mains!!.
then again whats the hot flow like??????????????
i actually installed a combi for customers dad, directly opposite. Same road, no issues
thanks everyone for your replies.
It's definitely not affecting the hot water only, mainly the cold water!! Although I have a pressure gauge, I only use it when I think there's a possible issue once tap/s opened.
what has happened here is the normal situation when you change a gravity system to a combi. When 2 cold taps are used the pressure is redced dramatically. Like opening a tap in the kitchen with a shower. Unless you have over 18litres a minute or what not. it must just have been what she was expecting. Is the pressure ok with one tap open? It sounds like it is from your post
pressure ok with one tap open ...... just when you open a second one. I've never had a issue with the cold mains being reduced this much ...... that'll teaech me lol
the hot and cold water are the same pipe/supply, so of course the hot can effect the cold . what you have is a poor flow rate. the water board will only garantee about 9 litres per min from memory. So when you turn the hot tap on the cold will have to share this 9 litres per min with the hot. if the hot tap has less restriction than the cold then it will get more flow or vise versa.
pressure and flow are two completely different things. You need to measure the dynamic pressure and flow rates of the cold main and if unsuitable for a combi boiler then fit an alternative system.
if you fit a combi or not that will never effect the flow on just the cold taps only if the hots run at the same time. regardless of mains changes is the stop tap in the house the one you turned off when fitting the boiler, have you checked the washer hasnt dropped or changed it ? its a cold mains problem if it happens when 2 cold taps are run not hot..it may well have been a problem anyway without you checking who knows. whats probablely happend is the've gone from tank fed bathroom cold now to mains and the problem wasnt evident before..
Oh sorry, I just read the post again. 2 cold taps. I was on about a hot and a cold. Forget what o said!!!
So you've got a few options:
1. Fix the root cause:
a. Check that ALL lead had been removed, maybe there is a bit still left somewhere upstream. (Like they replaced only a section of the lead with plastics initially, and now theu just went up to that plastic section, leaving the lead still upstream the middle plastic section.
b. Check all connectors/stoptaps for obstructions/blockages.
2. Mitigate the problem - get either:
a. 50 - 100 L expansion vessel, and fit it to the cold feed, with no-return valve to the outside+ kitchen cold.
b. 200L Water tank in the loft + pressure booster (pump with vessel)
c. Dial the hot water temp down to 40 - 42 degrees C on shower flow rate, so no need to open the cold tap. For dish washing let the owners up the temp by opening the hot tap partially, increasing the temp to 50 or so degrees.
And the problem will go away because the customer will contact legionnaires disease and die. Okay perhaps a bit melodramatic but hot water should be supplied at 50 degrees or more to prevent bacterial contamination, particularly at showers etc. where droplet inhalation is most likely.
This post should be a lesson to everyone, check pressure and flow of the cold main before fitting a combi and explain to the customers the drawbacks as well as the advantages. I always look for twice the flow rate required by the combi as a minimum to give a decent performance.
if they have had a new main fitted the water supplier wil test to see what volume of water there is at the boundary that will then tell you where the issue lies there could also be another valve upstream of the stop tap check all the pipework , connect a hose on to the new stop tap and see what flow rates you are getting there
I agree with AWheating you should have checked both static and dynamic pressure. However have you installed any isolation valves in the main cold water supply pipe that could restrict the flow. If you have replace them with a fullway valve. Also be careful if you decide to install a pump on the water main, if it pumps more than twelve litres of water a minute you will need to install a breaker tank. Even even though you have replaced the main water pipe this will increase the flow rate but it is not infinite, an average 15mm tap will use about 8litres of water a minute the more you have on the more the dynamic water pressure will drop.
I'm afraid there are two problems legionellas breeding inside a typical combi boiler or pipework after it: 1. The water doesn't sit there long enough (20-30 sec max when flowing), and you need at lest 4-5 hours in the favorite conditions for it to become a problem; 2. Usually there is no much nutrients for them in a clean tap water (unlike inside a split air conditioner) + there may be some chlorine/chloramine in there too. Also If your's incoming mains water is full of them, then the typical showering with 65 degrees hot MIXED with contaminated cold water to 39-38 would not eliminate them :-( I'm not sure anybody would like to take UNMIXED HOT shower at 50+ degrees... Legionellas can be a problem if you have an vented HW tank, with the head tank full open and full of dust sitting at 25-45 degrees for weeks. Also the host should have severely compromised immune system (or be 85 years+ of age). Than it is better to take a bath than a shower...
Since when has water only sat inside a combi for 20 -30 seconds? Mine is full of water all of the time and will regularly sit for 8 hours overnight without being used. If the hot water temperature is only set to 40-42 there is a chance of bacteria breeding.
In a typical mixer shower the cold water will enter at less than 20 and the hot in excess of 50. This minimises the risk.
Good practice in the prevention of legionella dictates that hot water in excess of 50 should reach the outlet (or mixing valve) within 1 minute and cold at less than 20 in less than 2 minutes.
Practically the risk may be low but should it occur you do not have the defence of having followed best practice.
Reply to assistancee required please guys in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
