Discuss Advice Appreciated - Considering Legal Action in the Plumbing Jobs | The Job-board area at PlumbersForums.net
cr0ft
Hi all,
Bit heavy for a Friday night but here goes...
Around 6 months ago we acquired a customer through Checkatrade. Very large heating system, house is about 300 square metres area per floor. Ground floor is a mix of suspended floorboards (25%) and thick concrete screed (75%).
The customer was losing pressure from the heating system and there was no sign of water leaking from the existing floor standing non-condensing oil boiler. To put the timescales between appointments into perspective, the customer is a 120 mile round trip from us and we explained at the time that she could be waiting as much as 30 days between appointments due to the unpredictable nature of the work and how busy our diary was.
In the order we have attended the house to carry out work: -
1.) 01/07/2015 - Initial visit after phone call to rule out the obvious things that may be causing the leak such as boiler, leaks from upstairs etc. During this visit we discussed that if the customer had one leaking joint under the concrete screed it was likely that more would follow. The customer was about to lay expensive tiles across the whole of downstairs so my recommendation was to re-pipe the downstairs heating from drop-downs so they would have confidence they wouldn't be digging tiles up again. This recommendation was rejected on cost grounds. So we moved on..
2.) 31/07/2015 - Second visit to carry out acoustic leak detection. We checked the whole of the ground floor and the only leak we could hear was a large leak under the hot water cylinder (typical, eh?).
3.) 10/09/2015 - Third visit to remove the hot water cylinder, dig out the floor underneath (8" concrete screed!), find the leak, cut out and repair the affected heating pipework. On completion of this work we agreed to leave the system running over the weekend before re-screeding. Big gap between appointments due to my holiday and theirs running back to back.
4.) 13/09/2015 - Fourth visit where we all agreed the floor was ready for re-screeding and their were no signs of any leaks or pressure losses from the heating system over the 3 days. Floor re-screeded and hot water cylinder re-installed.
5.) 27/09/2015 - Fifth visit, invited to do some unrelated drainage work outside the property. All completed and customer happy.
6.) 15/10/2015 - Sixth visit, pressure drop on heating system again. Traced to leaking pipework on central heating system near boiler, unrelated to previous work.
7.) 28/10/2015 - Seventh visit, stopcock had developed a leak on it. Valve repaired and job done in 20 minutes.
8.) 16/11/2015 - Eighth visit, pressure drop again on heating system! Asked by customer to attend and carry out acoustic leak detection again as no signs of leaks above ground anywhere. Acoustic leak detection carried out and no leaks under screed heard. We lifted all their floorboards where required for free to visually inspect all the heating pipes under the suspended floors too. No sign of any leaks. At this point I recommended they get a specialist leak detection company in to do gas tracing on the central heating pipework as I am aware this can find small leaks which aren't heard with acoustic leak detection.
9.) Gas leak detection company find a tiny trace of gas from under the hot water cylinder. We have offered to re-attend and dig up the screed and if our repair is faulty refund the second lot of leak detection work and repair it all for free. Customer has 'lost confidence' in us apparently. To me this seems strange after getting us in and paying for 6 separate jobs before hand. My opinion is that the acoustic leak detection work was carried out professionally as the other firm didn't find a leak with acoustic leak detection either, they had to use gas tracing.
10.) We have asked them to arrange an independent inspection of our work and if it's found to be faulty we will compensate them. We have been asking for this since 7th December and there has been no communication at all since then despite sending a letter before action on 23rd December and several emails before that.
All invoices for the first 6 visits were paid, most of them late, but the money always arrived. We haven't been paid anything for invoices 7 or 8. Even though the stopcock is over a metre from anything we have worked on she is saying we have caused it to start leaking (this isn't the case, it wasn't leaking at all when we left). She also didn't make clear when calling us out for this appointment that she had no intention to pay for it.
Money for invoice 8 was with-held pending investigation by them. Not heard a thing in over a month now since them saying this, despite plenty of requests for updates.
Should I start court action to recover my money? I feel I should in this case as I've received no evidence there are any problems with our work and prices were all agreed before hand. The outstanding amount is around £600 plus costs and interest (including VAT). The customer has had us put all invoices through their limited company which is run from their home address. The company accounts show a company that has around £60k of cash in the bank. They have company vehicles on the drive but they are behind a full height metal gate and brick wall so bailiffs wouldn't be able to recover them or get in...
Would appreciate your independent opinions.
after the 3rd time did you pressure test the system ?
bailif can force entry into a business address.
sounds like they are going to wind up company and not pay you, but they cant put all bills onto accounts and must be domestic element.
follow the court route and get it going, dont waste time!
if they pay before then alls good then dump the customer and move on.
drop a letter to the tax man that they are running their home bills through the company to reclaim the vat back :)
Hard one Crofty..
Is the amount your charging for invoice 7&8 worth the hassle?
If so, Why not send them a final Invoice along with a letter stating charges for additional costs if this matter goes to court. "Times, Dates, Calls made and hours used trying to rectify this situation.
If a customer asked me to travel 120 miles to start chasing leaks I would have told them to get someone more local
Personally I would let this one go and be happy in the fact that I wouldn't need to deal with job anymore.
tend to agree with TB, if no materials involved de stress and walk away, but letter to HMRC report line a must :)
The way i read this is that customer is annoyed that stopcock has started leaking (which they do).Wasn't before and in her eyes you have done something to cause this.
And again in her eyes i assume she paid you for repairing leak under cylinder in the first instance ,roll on later date a leak has been found by an outsourced company in the same place as you have repaired.
Does that read well in court???
To me, once pipework starts to leak under concrete then its all goosed. You can spend weeks repairing sections and chasing other leaks.
As they have been paying through their company then its a commercial debt. Chase them and hit them hard.
Absolutely nothing to do with this job but I'll tell the story anyway....
I remember going to a job that was leaking like a sieve.
The copper pipework under ground was somehow wrapped in plastic (I only saw under 2 tiles)
God knows how they did it, but....
The plastic wasn't appropriate for the job, I think it was supposed to be used to protect gas pipe.
Every time the heating expanded, a joint cracked! The original plumber tried to repair the leaks afew times but it wasn't any use. They wanted me to repipe the downstairs above floor. Never got the job mind.
ive had a few over the years constant battle as fast as you fix one bit another gives up the ghost but no one ever wants to rip it all out and start a fresh
Trouble is if you walk away it would eat you over the principle, did you touch the stoptap and was it just leaking from the gland?
This is why I don't travel more than ten miles to a job and its gets expensive for them and people fall out over money.
10 miles !!!!
I travel over 1 mile i get the jitters !!
The problem half the time when these things occur is that you advise them as croft has to repipe but due to cost they won't . They then expect miracles for pennies which in reality never solves anything, roll on a few months later you become the biggest git going even tho they ignored your previous advice.
I can often do 50 - 60 miles to get to a job, cover up to 180 miles a day for 4 jobs and wave to a colleague on the motorway as we pass each other going in opposite directions yet if we say anything we're told "It`s not your diesel".
Wouldn`t trust the office to organise a party in a brewery!!!
Croft seems to have done what anybody would do to a proper job, talking about mileage I do a lot of travel but I charge a rate otherwise I would be sat at home. I do suppose it depends on what you work with
I would send final letter then proceed with court action make sure you've got reference to the fact you have offer that if any of your work is faulty you correct and compensate accordingly,
To me it would look like you've been out advised that it would be better to re pipe whole system,
they dont want to pay,
you've fixed leak and now theres anouther leak, you where right about re piping and now they dont want to pay,
Put a brick through the car windows and dent the roof/bonnets, should total more than £600 in damage ;)
That's a ridiculous statement to make!!
Far better to quietly throw cellulose thinners over the paintwork. :grin:
Thanks all. We did indeed pressure test the pipework at around 2.6 bars for the 3 days in between making the repair and re-laying the floor which is why I am confident we didn't miss a leak at the time.
Am hoping that the judge understands all of this technical stuff though. The other firm didn't pick up a leak with their acoustic leak detection equipment either, they had to fill the heating system with helium gas to find what they thought was a leak. I made clear before hand that we only offer an acoustic leak detection service and explained the limitations of it.
Letter before action was sent on 23/12/2015 as I said I would.
Have put the court papers in and will update as to how it goes.
Thanks all.
Youve done things right and kept them informed along the way. As others have stated ud send them a polite but concise final reminder before action.
Then follow through.
Do ensure you itemise the charges due as a result of the action what will be added to the outstanding amount.
Alternately there are a few debt recovery places that will do the legwork and put the frighteners in them.
I dont envy you - its all stress and extra time.
I had a pain customer lately. Ancient diy system. Compression all over under the floor, dead legs. Probably an old 1 pipe turned into 2. Primaries all 15mm lol.
Fitted wireless controls and hes never off the phone saying now some radiators are only getting warm and others hot and its never the same twice.
Now I went back a couple of times and gave suitable advice at my expense. Now he hates the controls as he doesnt understand them. Buyers regret.
Blocked - at least i got paid.
Kid's these days arnt smart enough to know that though, where as anyone can throw a brick ;)
Sounds like they're just trying it on Kieran to avoid the payment.
The court process is relatively easy if they ignore it. As said, being a commercial debt means you've a lot more ground to in force it with. I think you'll be OK and I would definitely not have let it go.
Be interested to know the outcome of the court judgement, and how you faired with enforcing it which from my experience, is harder than the court judgement itself!
Been to court??
Kind of. I did some work for a company and didn't get paid. Went through the small claims procedure which is all online and they didn't appeal in the given time, so I won by default.
As I was enforcing the CCJ the company was wound up by BSS for non payment of their account. I got a letter through from the administrators which showed they owed about £80k to various debtors, so I didn't get a penny.
Which actually reminds me, I never did get my revenge.
I was in the process of taking eaga heat to court over unpaid money , they ended up paying me twice and never realised ,,,, bonus !!
been there with a nursing home grrrrrrh
Reply to Advice Appreciated - Considering Legal Action in the Plumbing Jobs | The Job-board area at PlumbersForums.net
