Discuss A look inside a hot water cylinder. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
When they are like that they are difficult to drain down and just a tad heavy!
Never take a cylinder like that apart as the scrap man will give you less for it.
I think he wants top chop open a cylinder from around here.
We had one, could only pour 15/20 litres of water in Till it was filled up!
The water in England must be poor! Water over here, in a lot of areas is good & limescale is unknown. Have seen some grade 3 cylinders here in shiney clean order inside after 20 plus years.
Some yards give u a tank price and not a weight price due to scales. The north east is no where near that bad 180ppm
that bloke just liked getting his chopper out
...don't we all! :grin:
Must admit, he seems to know how to use his chopper well. Never thought that a copper cylinder insulation could come off so easily!
You have to respect a man that knows his chickens ;)
Will have a look through some of his vids now, wish me luck, I usually get very lost and end up in a nasty corner of youtube after about 4 or 5 videos...
Not all water heating system are created equal ,some water heating are more efficient than others, and efficiency can also vary between models of the same type.
Reply to A look inside a hot water cylinder. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
