Discuss 750mm wide radiator? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
michaelmorris
I'm looking to replace a 750mm wide radiator in a bathroom. I want it to be the same width and I don't want a towel rail. Any ideas gratetfully received. Thanks
You might struggle to get one that width. It sounds like an old imperial size. The closest you will get will be 700mm wide and use radiator extensions to get the correct pipe centres.
Myson premier HE 743mm wide. Any decent plumbers merchant will get you one.
Heights are 390, 530 and 690mm.
Thanks - Pretty pricey, but a lot less hassle than taking up the bathroom floor to alter the pipe width.
Reply to 750mm wide radiator? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
PSxxxxxx
My son has an apprenticeship interview for to become a plumber and heating engineer. The have said there will be a multiple choice exam for this...
