Discuss 3 port valve fitted wrong way around in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Are you sure it's a mid-position, not a diverter valve (two positions only, CH or HW, no mid-position, CH and HW)?If mid position valve is fitted the wrong way around
Quite rare these days?Are you sure it's a mid-position, not a diverter valve (two positions only, CH or HW, no mid-position, CH and HW)?
Diverter valves are frequently used on systems with Weather Compensation or Opentherm as the flow temperature can be much lower when CH is called. A mid-position valve is unsuitable in these situations.Quite rare these days?
Reply to 3 port valve fitted wrong way around in the Plumbing Jobs | The Job-board area at PlumbersForums.net
