Discuss £250 for an outside tape in the USA area at PlumbersForums.net
No I didn't, stupid really, it a recommend from a friend.Did you get an estimate or quote before it was installed?
How thick a wall is it, water available directly inside or has it needed a bit of pipework?
No, tap just out the side kitchen window.£250 quid !!! I see Dick Turpin is alive and kicking . How far has he run the pipework, all way round the house .
When was the work done? If you called out a plumber in the middle of the current covid-19 lock-down you might expect to be charged 'emergency rates' and extra for PPE, which is expensive and difficult to get hold of these days. They might have had to go a long way to get the brassware because their usual merchant was closed, etc.No I didn't, stupid really, it a recommend from a friend.
Because under the Supply of Goods and Services Act 1982, in default of pre-agreement of how the work would be carried out and at what price, the work should be carried out to reasonable standard, at a reasonable cost.Surly this is your mistake, why would you expect a refund? Your a adult who made a bad transaction that’s all.
The OP presumably didn't agree the cost before the work took place and felt the price was unreasonable. On which, lacking evidence, I'm not going to comment.
WHO is talking Supply of Goods and Services Act? Actually, I was, not the OP.What planet you on? This is how deals are done between men..
You “I need a quote for a outside tap mate?”
Plumber “I can supply and fit it for £250?”
You “yes please (OR) no thanks”
You “go ahead”
Plumber “does job as agreed”
You made a deal with a guy, now your talking nonsense, it don’t matter if he charged £2500 if you agreed to the price! Now your talking supply of goods and services Act...good luck with that one. Smarten up
Reply to £250 for an outside tape in the USA area at PlumbersForums.net
