Currently reading:
10mm chrome plated street elbows.
Discuss 10mm chrome plated street elbows. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
SimonG
Subscribed
Looking for 10mm chrome plated street elbows compression or speedfit.
Any ideas.
Thanks.
Deadly serious.
Customer wants plastic central heating (10mm SF), fine no probs, but I want a neater job to the downstairs rads. Hence 10mm rad valves with a 10mm chrome elbow into the bottom of the valves to accept sf pipe. Screw fix do the trv with the 10mm chrome sf elbow, just want to procure the elbows without the valves.
Almost every good plumbers merchants will sale them, we mostly use Myson one which look pretty neat.
they make for a nice neat job on 10mm no pipes out of the floor you running from above or below ?
Both, 4 up, 3 down, up I'll get the pipes up behind skirting and rad and into the valve and the ones down stairs are on stud walls.
one problemyoull find is without the pipework to hold them smaller rads float about on the brackets your best to spread the bracets to as wide as you can so they lock the rad
if pipe is coming up behind the skirting let it loop up then down and out towards the valve this allows rads to be lifted of to decorat with out draining
Reply to 10mm chrome plated street elbows. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
