Discuss 1/2 rad tail for rad spanner in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am wanting to fit a TRV but the radiator tail that come with all the TRVs I can find have the spanner flats on the outside not the inside. The problem is they need a greater distance between rad and pipe. I thought if I could replace the tail piece with a shorter one that still fits on the 15mm compression fitting then that would solve the problem. The existing manual valve is like this (10mm pipe) http://www.NoLinkingToThis/p/chrome-angled-radiator-valve/51257#product_additional_details_container
not sure what you are saying but the valves on screwfix site are 10mm if you have got new valve that has a 15mm connection then you need a redusing set that fitts in side the 15mm compression as for the conection to the rad one you spanner in the outher you will need a rad spanner that tights from inside but they are the same distances
Won't get it sorry op best to alter Pipework
Chris: he's trying to fit the loose nut part to a stnd trv body
You may have a bit of play in the pipework, try enlarging the holes in the floor boards where the pipe emergies and simply move them over a bit. If you do both sides you could push the rad over a bit more on it's brackets to give you just enough room. It usually works.
You can cut a piece off the new rad tail no more than 10mm though bud cheers k
I've read it twice, once sober and now drunk. Struggling to figure out what the op is trying to do.
i think we are all at a loss as to your problam can you take a photo so we can determene the out come thanks chris
fit a trv by replacing a lockshield valve
but the trv pipe centres as you know it pushes it out more than a stnd locksheild valve
he wants connect the trv to the lockshield swivel / loose nut
Got it. Cheers
the lock shild and a tvr should be the same 4cm on each he only needs to change the union in the rad then or have i lost this in translation please send a photo to put us all out of are miery
Sorry I wasn't clear, and thanks to those who have helped clarify. You have now got to the heart of it Chriswareham, TRV's need 4cm and the standard only 3cm. I had thought I would need more than 1 cm looking at the manufacturer's diagram. I wasn't worried about the downstairs one as the pipes are dropped from upstairs and so I thought there would be enough play, but the upstairs are very short. I have now dug some holes in the walls, as suggested by Darren, and bent one pipe slightly (without changing the angle going into the valve) so I'm sorted - thanks guys. I can now order the valves. :)
The measurement on the diagram is to the internal end of the tail though this is not clear (why would you need that?). I only know it now, so I thought I needed 3 cm not 1cm.
The tail connected to the radiator is a 3/4" socket, TRV valves use a 15mm male and if you need a longer tail City plumbing sell long tails for Radiator connections
This is a problem I often come across when replacing radiator valves or radiators. I wish someone would manufacture 15mm rad valve tails that have no nut shape for spanner, but instead have an internal for Allen key. That would gain at least 12mm for a longer shaft on the tail.
As other replies, - screw tail fully tight, cut a small amount off tail if needed, ease pipework if possible.
Reply to 1/2 rad tail for rad spanner in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I need some advice. I am trying to replace the manual radiator valves on a towelrail with a TRV: I ordered a Myson 2TRV15SN, and the tail...
A
Hi, I am trying to fit a replacement tap to a mini-sink that's built in to the top of a toilet. The original tap isn't made any more by the...
I have had a problem where 2 downstair radiators are not heating up the same as the rest of the radiators around the house, now previously i had...
Hi - I'm a reasonably experienced DIY plumber but just can't work out why the last new rad I've installed is cold - would really appreciate your...
I am trying to workout in what order my radiators heat up in order to then balance them. I am able to figure out which radiator pipe is the...
