Discuss Zoning in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Leo21
Subscribed
Who,s doing it and in what situations? What exactly are the rules? I from memory read somewhere that retro fit wise it's all to do with what your replacing. As in a boiler replacement doesn't require any upgrades.
Not even the mighty BG fit zones round my way.
Tbh adding in the extra cost would price me out of most jobs, specially when my competition aren't quoting like for like.
Can you get them to sign a waiver or have it as an optional extra?
No it's building regs
Try and zone house to bits. Normally old dears ask that bathroom on 24/7 so just fit zv and rf programmable stat set to constant and 21.
Use old primary pipe work some times for this run.
Over 150m2 new install req zone valve up or down? And trvs and a programmer and a stat oh and a boiler .
I don't know anyone who is doing it on housing association or council houses. But I bet you a pint of absinthe that mike Jackson's zoning!
I haven't zoned a system yet. Too much hassle when you're doing a boiler swap in a small house.
Full install I would consider it depending on the customers view on spending.
zone new build and properties over 150m2, anything else is given as an option if worth trying.
Zoned last 3 sites upstairs and down all new build. Combi boilers, flow/return to a/c then zone valves to heating with bypass across boiler flow/return.
Did one site, 3 storey house, zoned the top floor and 1st and 2nd floors (total 2 zones). The top floor had one rad!!
So that's 75m2 per floor if it's two storey?
We did a close of houses all over a ÂŁmillion, minimum 4 bathrooms in each and all those houses were zoned. Made a manifold up with lots of outlets and took it from there.
So in my opinion you use it in large properties generally.
when I did energy eff I was told any dwellings with upstairs even terrace need zoning even if under 150m2.but heard they changing it back.called my local planning office who didn't have a clue
Reply to Zoning in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented...
Hi all, I have a Heatmiser UFH installation, 7-8 years old now. This week we noticed that a few of our heating zones were not warming up, even...
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
I live in a large 3 bed semi with a Potterton Profile 60e - so it's a G rated boiler. I wish to improve the energy efficiency of the property...
Hi all, sorry about the long post but a novice here looking for some advice... I've just bought a 12 bedroom private house with 3 bathrooms that...
