Discuss zonal heating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I
ip26150
on a job where the main circulatory seems fine on three zones ,but the single problem zone ,which i am working
on ! ,goes from the cellar (boiler situ) up to first floor up 4.8m ,then down 2.4m .
the 4 radiators here are tardy in heating up and do not seem to get as hot as rest ,
i am thinking i would like to fit a booster pump just on this zone at first floor level ,
could someone advise me on pump choice
Are they slow even with just the one zone heating? Is there a bypass, if auto what is it set at?
have tried to balance the radiators ,running the single zone ,but though better still not right ,
flow seems reluctant ,to go up the 4.8m ,then down 2.4m ,then return up 2.4m ,on the return ,
before the return drops back the 4.8m ,
know its a different situ ,but discharge pumps ,will only go so far vertically ,then if you put a
horizontal run in ,they refuse to go any further vertically ,
really do appreciate your input as need to rethink this problem ,so i can relax and concentrate on
my planned drinking and gambling normal saturday
Whats the total amount of heat you need to flow, and pipework resistance for the run also what pump is currently fitted?
Is this an older install ,
has the slower leg acted as a place for sludge to gather ?
( ie a clean and a re-balance )
what about partially repiping so the pipes only have to go up 2.4m not 4.8m and then do the same for the return.
Reply to zonal heating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Afternoon Fellas If anyone has time to help with this snag it'd be much appreciated. We have a wet-floor system controlled by John Guest UH3 and...
A bit of clarification - I have extended a 3 bedroom semi detached and at the time central heating pipes were going in I told the plumber could I...
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented...
Hi, I have 3 port value for HW & CH. Loft extension added many years ago so they added a T to go upstairs, only 2 rads up but 11 downstairs...
Hi thank you for letting me join this forum . We have an air to water heat pump but the bungalow is piped in micro bore 10mm pipe which doesn’t...
