Discuss Worcester filter power flush adaptor in the Central Heating Forum area at PlumbersForums.net
Does anyone know if you can buy an adaptor to fit on the unions of the worcester filter so you can connect magnaclense power flush machine connections ?
The new type eg like the maggy pro 2 28mm ones ?
if you have the ADEY flush box eg the blue blow moulded one with the adapters in
you should see two of these
They will fit
Oh ok thanks Shaun. I have got that yes. Buried somewhere in my garage. Think it may be quicker to buy a new one than search my garage !!
Reply to Worcester filter power flush adaptor in the Central Heating Forum area at PlumbersForums.net
  • Sticky
Does anyone know a good, not super expensive, leak detection company in the London area?
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
