Discuss Worcester filter power flush adaptor in the Central Heating Forum area at PlumbersForums.net
No the Worcester Magnetic filter. Or are you saying the larger magnaclean adaptor unions will fit ?The new type eg like the maggy pro 2 28mm ones ?
Yes this type Shaun. It's the standard 22mm onethis type ?
Greenstar System Filters Professional | Worcester Bosch
Central heating system water accumulates harmful dirt and debris. The Worcester Greenstar System Filter has been specifically designed to combat these damaging effectswww.worcester-bosch.co.uk
Oh ok thanks Shaun. I have got that yes. Buried somewhere in my garage. Think it may be quicker to buy a new one than search my garage !!if you have the ADEY flush box eg the blue blow moulded one with the adapters in
you should see two of these
MagnaClean Professional2XP (28mm) and Greenstar mk2 (22mm & 28mm) MagnaCleanse adaptors
MagnaClean Professional2XP (28mm) and Greenstar mk2 (22mm & 28mm) MagnaCleanse adaptors ADEY Innovation Ltdwww.adeyspares.co.uk
They will fit
Same as addey kit in blue manifold boxDoes anyone know if you can buy an adaptor to fit on the unions of the worcester filter so you can connect magnaclense power flush machine connections ?
Reply to Worcester filter power flush adaptor in the Central Heating Forum area at PlumbersForums.net
