Discuss worcester bosh greenstar ri wiring in the Plumbing Jobs | The Job-board area at PlumbersForums.net
g60rge
hey guys, just been to quote for a job to replace the wiring center/programmer along with fitting a new greenstar ri.
just researching the wiring as i only really fit combis
ive noticed i need to wire the pump direct to the boiler for the pump overun - got that bit
in the boiler we have a LNE in and a LNE out - whats the out for? >when there is no spur near the wiring center?
i have a spur available at the wiring center, does this mean i dont need to use the out as i can run LNE from the spur to the wiring center then to the boiler in section
not forgetting switch live from the wiring center to the boiler
let me know if this doesnt make sense
thanks
For an Ri you'll need a 5 core
Permanent live, neutral & earth, plus a pump live & switch live...
A lot of the Worcesters have live to wiring centre etc but you don't need to do it that way...
yes as gas safe said the boiler will require mains power
Mains power 230v connection fused 3 amp (ST1):
– Connect LIVE wire to terminal (L)
– Connect NEUTRAL wire to the terminal (N)
– Connect EARTH wire to earth bracket
External Pump (to pump)(ST2):
– Connect LIVE wire to terminal (Lp)
Boiler Demand (ST2):
– Connect SWITCHED LIVE wire to terminal (LR)
and then wire it like normal in the wiring center minus the live for the pump as that will be coming from the boiler
Reply to worcester bosh greenstar ri wiring in the Plumbing Jobs | The Job-board area at PlumbersForums.net
When I set it to be on via phone, light A comes on (telling it to be on), but light B won’t come on, so the boiler doesn’t start. I either need to...
Looking for a gas safe engineer to complete a boiler and cylinder install in Ringwood BH24. There was a delay of approx 8 months from the install...
Hi there, My boiler (Worcester Greenstar Ri) has started making a soft knocking noise when it turns on, and again a few times when it turns off...
Hi Everyone - despite my best efforts I can't seem find a clear answer on how to wire a single channel Hive Receiver to a Worcester Bosch...
3K
Experiencing an issue with a Worcester Greenstar 21i conventional boiler if anyone could help! I have previously installed a Tado smart controls...
