Discuss Worcester Bosch bonded washers?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
macka09
hi guys. Can anyone explain why Worcester use bonded washers on there gas connections rather than a normal fibre???
better seal and garanteed
Another silly question Worcester related. Are we able to check whether a boiler is for nat gas or lpg with the gc number.
no but gas valve is labeled
Reply to Worcester Bosch bonded washers?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a Worcester Bosch Greenstar 30Si combi boiler, the analog clock has stopped and the On-Timer-Off switch only works on Timer setting...
hi everyone a local installer has recently quoted me £3,660 for a complete install using the main eco compact 25kw boiler i have also been...
2K
Deleted member 131795
Hi I'm new here so go canny with me. Hoping that someone can help with the following concerning weather comp, it is a Worcester Bosch comfort+ll...
T
Hello, I have just moved in to a new flat this week and have a problem with noise coming from somewhere around the top of the boiler. It's a loud...
I know no one really does. But technically why should we use bonding clamps when we cut a section of gas or water pipes out? Thanks.
